Adding Tags on Components
Jump to Best Answer
  • 1.  Adding Tags on Components
    Posted 11 days ago
    We've recently upgraded to the cloud. Our old version (2015.5) had a separate field for tags but that field is not part of the configuration of the item. How can we add tags to components?
    Rebecca Tremain
    Senior Business Analyst
    GEHA
    Lee's Summit MO
    816-257-5500
  • 2.  RE: Adding Tags on Components
    Best Answer
    Posted 11 days ago
    Hello Rebecca,
    Great question! You can add the Tags field to a Component (or other item type) using the following steps:
    • Login to your instance as an Administrator
    • Go to Admin > Item Types > Component > Edit > Add Tags to Active Widgets
    • Go back to a Project and add or edit a Component
    • You should now see the Add Tags field on Components
    I hope this information was of help to you! Please reply if you have any more questions :)
    Giselle Northy
  • 3.  RE: Adding Tags on Components
    Posted 10 days ago
    This worked perfectly. Thank you!
    Rebecca Tremain
    GEHA
    Lee's Summit MO
    816-257-5500
