ws.jamasoftware.com inaccessible
  • 1.  ws.jamasoftware.com inaccessible
    Posted 05-17-2019 09:27
    The site "http://ws.jamasoftware.com/latest" which hosts the Jama SOAP web services API documentation no longer seems to return any response. Could this please be brought back online?
    Thanks.
    Ryan Dill
  • 2.  RE: ws.jamasoftware.com inaccessible
    Posted 05-17-2019 10:40
    Ryan:
    Unfortunately, our SOAP API and all support has been EOL'd at this time. Please see this article outlining the process: SOAP API end of life plan. We do fully support our REST API!
  • 3.  RE: ws.jamasoftware.com inaccessible
    Posted 05-17-2019 11:01
    Thanks Chloe -- I'm aware that the SOAP API was EOLed -- however, it remains the only API available in pre-Jama 8 versions like Jama 2015.5. Last I heard, Jama 2015.5 was still being provided best-effort support, and its external documentation such as release notes are still available -- I would expect that its API documentation should continue to be similarly available.
    Migrating from pre-Jama 8 to Jama 8 may require migrating SOAP API scripts to REST API -- this becomes much more difficult for the customer when Jama Software has removed its SOAP API documentation.
    Please advise
    Ryan Dill
  • 4.  RE: ws.jamasoftware.com inaccessible
    Posted 05-17-2019 11:13
    We are also in this migration process, so to have SOAP documentation available will be a plus.
    Regards, Saludos
    Lilliana
  • 5.  RE: ws.jamasoftware.com inaccessible
    Posted 05-17-2019 11:43
    Ryan and Lilliana:
    Thank you for your information provided here. In order to understand how best to support your redeployment, we need to know how you currently utilizing the SOAP interface?
  • 6.  RE: ws.jamasoftware.com inaccessible
    Posted 05-17-2019 12:16
    Hi, Chloe -- can you clarify on what details you're asking? "How are you using it" is a bit generic. :)
    FYI, we're currently using the SOAP API to do a variety of management tasks:
    - Clean up (i.e. deactivate) Jama users when they become inactive in LDAP;
    - Clean up Jama items with unsupported unicode characters in the Name or Description fields as a result of IBM DOORS or Microsoft Word imports;
    - Clean up Jama PNG images resulting from IBM DOORS imports, which can incorrectly have the database SYSTEM=Y flag set;
    - Bulk recover item Status values after a conversion of one item type to a slightly different item type;
    - Search through the project Activity Stream to find deleted items matching certain criteria (since deleted items are no longer searchable via normal means);
    - Query the email addresses of all active users in Jama, in a format suitable for adding to a BCC'd "all users" email;
    etc. etc.
    Honestly, I'm not sure why you need to know this information, though -- I'm not particularly asking for personal support in doing the API conversion -- I'm just asking for the SOAP *documentation*, so that I can continue doing the API conversion myself, if and when I find time.
    I can't imagine that Jama doesn't still have a copy of the content that was previously available on ws.jamasoftware.com archived *somewhere*, whether in HTML form, PDF form, Word form, whatever.
    If you consider it too much of a support headache to continue hosting this online, I can understand, and I would happily accept a static copy that can be sent to customers still using SOAP, on request.
    Ryan Dill
  • 7.  RE: ws.jamasoftware.com inaccessible
    Posted 05-18-2019 11:45
    Ryan:
    Thank you for your time and patience in producing this answer, I am working diligently on getting you what you need. Your answer is helping us to understand the best format to provide this information to our customers. Again, I thank you for your patience, we want to support you in your efforts here.
    Regards,
