Field type = Steps
  • 1.  Field type = Steps
    Posted 08-11-2021 18:53
    1. How can I create a custom field type that works similar to Steps?
    2. I don't see Steps in either the Predefined field type nor Custom field type.  Where is it?
    Khuemy Nguyen
    Soliel
    Vienna VA
  • 2.  RE: Field type = Steps
    Posted 08-13-2021 11:42
    Edited by Decoteau 08-19-2021 08:50
    Hi Khuemy,
    Test Steps can only exist in an item that has been designated to be used as a Test Case.
    You can change any item to make it behave like a Test Case. Once an item is being used as a Test Case, the Steps will automatically be added. There is no way to manually add Steps to any item.
    Please see this article for more information - Use a different item as a Test Case or Defect - and let me know if you have any questions.
