Thanks for the information. We use the coverage view to generate our trace matrices for regulatory submission. It would be helpful to save, edit, and move to different projects in Jama.
Also, I have noticed a bug and created a workaround on this coverage view feature. When I create a new coverage view and export to Excel it seems to have all the round trip information exported too. If I save the coverage view, close the coverage view window, reopen, selected the saved coverage view, and export to excel - it works.
Andrew Brown
Galil Medical
Arden Hills MN
Sent: 08-08-2017 16:58
Subject: Coverage Views
Hi Andrew!
This is addressed in a throwaway line in the User Guide; "Only the creator can rename or delete the view." The only change that can be made to an existing coverage view is a rename; otherwise you'd have to create a new view, if you want to change the content.
Sent: 08-08-2017 12:05
I'm using a coverage view created by someone else. There is an error that I would like to fix. Where do I edit an existing coverage view? Is the coverage view edit only visible to the creator!?
Thanks.
Andrew Brown
Galil Medical
Arden Hills MN
