Cancel button does not work, after editing a field in a Test Case.
Jump to Best Answer
  • 1.  Cancel button does not work, after editing a field in a Test Case.
    Posted 03-14-2017 16:49
    Steps to reproduce:
    1. Select a test case
    2. Edit a test step, such as add a note 'This is a note' into the Notes field.
    3. Save & Done
    4. Select edit too the test step again.
    5. Delete the letter 'a' from 'This is a note'.
    6. Click cancel button (nothing happens)
    Save and Save &Done works, but cancel = does nothing.
    Ken G
    ASR
  • 2.  RE: Cancel button does not work, after editing a field in a Test Case.
    Best Answer
    Posted 03-15-2017 11:01
    Hi Ken,
    Thanks for the report! I just filed a bug for this issue: SOS-DEF-1737. I clarified that the edit must occur in the same session (e.g. if the user logs out, and then logs back in, and then deletes content from the test step, the Cancel button will work).
