Is it possible to convert a filter to a lucene search? We need to set up a config with the legacy JIRA connector and we know the filter to use, but I'm unsure of how to convert it to a text based lucene search. Below are the criteria the filter is built with:
- Item Type = Spec
- Has all of these tags: Tag_1
I've gotten
tag:"Tag_1"
to return successful results, but it returns any item that contains that tag. We would want items that contain only that tag ideally. I'm unsure of what the text value to search by item type is. Thanks
Doug
