Add additional fields to Test Steps
  • 1.  Add additional fields to Test Steps
    Posted 19 days ago
    Is there any way to additional fields to the Test Steps beyond just  Actions, Expected Results, and Notes? We would like to be able to add parameters, initial condition, requirement number, etc to the test steps
    Thank you
    Jason
    Jason Barton
    VMS
    Palo Alto CA
    6504246216
  • 2.  RE: Add additional fields to Test Steps
    Posted 19 days ago
    Edited by Decoteau 19 days ago
    Hi Jason,
    You cannot add fields/columns to the Test Steps field.
    However, if you want to ensure that Test Runners/users are filling out parameters, initial condition, requirement number, etc then you could add a custom field and mark it as Required.
    You could put this custom field in the Test Run so the user is made to fill it out before they save a Test Run Execution, or you could add it to the Test Case itself.
    In the 8.53 Release Notes, we provided an example of how one might use a custom field in a Test Run:
    • Configure custom fields to appear when executing a Test Run - Add fields to the Test Run item type to have access to them when executing a Test Run.
    Example: Add a test field to capture the serial number for a product being tested.
    I hope this helps!
