Explorer View - Set, Node Limitation?
  • 1.  Explorer View - Set, Node Limitation?
    Posted 12-11-2018 08:37
    In the explorer view where I have a set containing multiple requirements it doesn't seem to be displaying all the objects.  I know that there > 350 requirements but I only count 250 items in the explorer view ?
    Is there a limit on how many are displayed in this view or is it a bug?
    Andy.
    Andy
  • 2.  RE: Explorer View - Set, Node Limitation?
    Posted 12-11-2018 10:30
    Edited by Chloe Elliott 12-11-2018 10:31
    Hi Andy:
    You are not seeing the full >350 items in the Explorer Tree due to a default 'max Items displayed' set at 250 items. This number can be reconfigured to accommodate a larger number of items but, we warn that increasing the amount could cause performance issues.
    You can change this setting by going to Project > Configure Project > Settings > Edit and then enter the desired number. I found this screencast outlining this process: Configure Explorer Tree items
  • 3.  RE: Explorer View - Set, Node Limitation?
    Posted 12-12-2018 02:27
    Hi Chloe - Thanks for the clarification.
    Andy
