Velocity Excel exports not working after switching to Jama 8
Jump to Best Answer
  • 1.  Velocity Excel exports not working after switching to Jama 8
    Posted 08-29-2017 06:05
    Edited by Kristina 08-29-2017 16:09
    we have noticed that at least one of our velocity exports that generates excel does not work anymore after we have switched to Jama 8. When we compare the exported files in a text editor the exports from Jama 8 contain a header that is not beeing generated in Jama 2015:
    MIME-Version: 1.0
    Content-Type: multipart/related; boundary=3D"=3D_JAMA_BOUNDARY"
    This document is a Single File Web Page, also known as a Web Archive file.
    If you are seeing this message, your browser or editor doesn't support Web Archive files.
    Please download a browser that supports Web Archive, such as Windows® Internet Explorer®.
    --=3D_JAMA_BOUNDARY
    Content-Location: file:///JAMAVELOCITY/JamaVelocityRoot.htm
    Content-Transfer-Encoding: quoted-printable
    Content-Type: text/html; charset=3D"windows-1252"
    We have not been able to determine why this happens and how we can fix the report.
    Any help is highly apreciated.
    Anna + Ekaterina
    Anna Henke
  • 2.  RE: Velocity Excel exports not working after switching to Jama 8
    Posted 08-30-2017 01:53
    Thanks for making that visible for us.
    We have overlooked that at testing Jama8, we have been short before deploying it.
    Is a workaround available for that?
    Currently this is in our environment a showstopper for Jama8.
    regards
    Harald
    Harald Hotz-Behofsits
    Frequentis AG
  • 3.  RE: Velocity Excel exports not working after switching to Jama 8
    Posted 08-30-2017 03:31
    Harald,
    does that mean that you experience the same issue?
    We have filed a support issue in parallel to this call, but there is no solution for it yet.
    I tested a Velocity template provided by Jama (https://github.com/JamaSoftware/Community-Reports --> Upstream traceability) which generates Excel as well, and this report works.
    The main difference seems to be that Jamas excel export is rendering the tables in HTML, our excel-reports don't.
    I have not yet been able to dig into it further than that and was hoping that someone in the community already solved this...
    Anna Henke
  • 4.  RE: Velocity Excel exports not working after switching to Jama 8
    Posted 08-30-2017 04:02
    Harald,
    the Velocity engine was changed from 1.6.2 to 1.7 with Jama 8.10: http://velocity.apache.org/engine/devel/changes.html
    We have been pointed to a known issue with variables in macros.
    As we don't use macros in that template we can rule this out - unfortunately... we keep comparing reports, as it seems as if not all reports exporting to excel are affected.
    I'll let you know in case we find something useful.
    Anna Henke
  • 5.  RE: Velocity Excel exports not working after switching to Jama 8
    Posted 08-30-2017 05:07
    We have been able to narrow down the problem a little more:
    This happens if the contents of a richt-text field containing images is being placed inside the resulting excel.
    Additionally - for each image that is contained a bracket will be placed at the very beginning of the result report.
    This scrambles the excel-report so much that excel does not render it at all anymore.
    We will keep investigating this tomorrow.
    Anna Henke
  • 6.  RE: Velocity Excel exports not working after switching to Jama 8
    Posted 08-30-2017 15:18
    @Anna Our reports writer, Shawnna, checked in with me about this situation you are reporting. She noticed that the header of the report looks like it is in MHTML. Initially she recommended running the report as .html and then changing the extension to .xls before attempting to open the report. But then we saw your reply about your narrowing down the problem to rich text fields with images. Shawnna recommends converting reports written with HTML to MHTML because the image handling is better. If you can do that, it's where I recommend you start.
    @Harald I saw you also submitted a ticket about this. Are you reporting the same issue as Anna originally pointed out (you're getting a header that previously wasn't exported), or is it something else? Additionally, did you see the common theme Anna did about the failing Excel reports all containing a rich text field with an image?
    Ultimately if we can identify a common thread here I would like to file a bug. If you could attach copies of the report in question (both the template and the example output) to your support tickets, that would help.
    Since we're on the topic of Velocity changing, I should point out some things you might have missed. I don't know if any of these things are playing a role in the issue at hand, but I thought I should bring them up.
    --In 8.02 we changed how image security works. Previously it was an optional setting. With 8.02 we enabled it as a permanent feature of the product, which meant we began embedding images in reports rather than linking to them from the report. Any user who downloads or receives a report will see all images since they are directly embedded. If you are an organization that had turned off image security in the past, you will now see broken images in previously-generated reports. This means you will need to regenerate the report. Additionally, users will need to take an extra step if they generate a Velocity report (including the built-in All Items report) and attempt to upload the report to Jama as an attachment. The report will first need to be saved as a Word document before being uploaded. Any user who downloads or receives a report will see all images since they are directly embedded. If you are an organization that had turned off image security in the past, you will now see broken images in previously-generated reports. This means you will need to regenerate the report. Additionally, users will need to take an extra step if they generate a Velocity report (including the built-in All Items report) and attempt to upload the report to Jama as an attachment. The report will first need to be saved as a Word document before being uploaded. Any user who accesses an attachment or image via direct URL will need to be logged in.
    --As you pointed out, in 8.10.1 we upgraded Velocity to 1.7, which introduced a difference in how macros work. But since you aren't using them, it shouldn't affect you. That said, there may have been more effects from the Velocity upgrade that we are unaware of, since we only test reports the default reports included with Jama. Your custom reports may use functionality we don't, so we'd be unaware of the change.
  • 7.  RE: Velocity Excel exports not working after switching to Jama 8
    Posted 08-31-2017 02:13
    Edited by Anna 08-31-2017 02:15
    I have stripped our report as much as I could and this is the code to simualte the issue nicely:
    ########## START: GLOBAL DAOS #############################################
    #set( $docDao = $applicationContext.getBean("documentDao") )
    #set( $documentNodeDao =$applicationContext.getBean("documentNodeDao") )
    #set( $documentFieldDao =$applicationContext.getBean("documentFieldDao") )
    #set( $itemDao =$applicationContext.getBean("contourItemDao") )
    #set( $userService = $applicationContext.getBean("userService") )
    #set( $userDao = $applicationContext.getBean("userDao") )
    ########## END: GLOBAL DAOS ###############################################
    ########## START: VARIABLE DECLARATIONS ###################################
    #set( $user = $userService.getCurrentUser() )
    #set( $targetDocument = $documentList.get(0) )
    #set( $testCaseName = $velocityReportUtil.getValueForField($targetDocument.document,"name",null))
    #set( $testCasePrecondition = $targetDocument.document.description )
    ########## END: VARIABLE DECLARATIONS #####################################
    <?xml version="1.0"?>
    <?mso-application progid="Excel.Sheet"?>
    <Workbook
    xmlns="urn:schemas-microsoft-com:office:spreadsheet"
    xmlns:o="urn:schemas-microsoft-com:office:office"
    xmlns:x="urn:schemas-microsoft-com:office:excel"
    xmlns:ss="urn:schemas-microsoft-com:office:spreadsheet"
    xmlns:html="http://www.w3.org/TR/REC-html40">
    <DocumentProperties xmlns="urn:schemas-microsoft-com:office:office">
    <Author>$user.firstName $user.lastName</Author>
    <LastAuthor>$user.firstName $user.lastName</LastAuthor>
    <Created>today</Created>
    <Company>MeVis BreastCare GmbH & Co. KG</Company>
    <Version>2.0</Version>
    </DocumentProperties>
    <ExcelWorkbook xmlns="urn:schemas-microsoft-com:office:excel">
    <WindowHeight>9915</WindowHeight>
    <WindowWidth>22995</WindowWidth>
    <WindowTopX>480</WindowTopX>
    <WindowTopY>255</WindowTopY>
    <ProtectStructure>False</ProtectStructure>
    <ProtectWindows>False</ProtectWindows>
    </ExcelWorkbook>
    <Worksheet ss:Name="Scenario">
    <Table>
    <Column ss:AutoFitWidth="0" ss:Width="200"/>
    <Column ss:AutoFitWidth="0" ss:Width="547"/>
    <Column ss:AutoFitWidth="0" ss:Width="416"/>
    <Row ss:AutoFitHeight="0" ss:Height="18.75">
    <Cell>
    <Data ss:Type="String">&nbsp;</Data>
    </Cell>
    <Cell>
    <Data ss:Type="String">Name: $testCaseName </Data>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    <Row ss:AutoFitHeight="0" ss:Height="16.5">
    <Cell>
    </Cell>
    <Cell>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    <Row>
    <Cell>
    <Data ss:Type="String">Preconditions:</Data>
    </Cell>
    <Cell>
    <Data ss:Type="String">$testCasePrecondition</Data>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    </Table>
    <WorksheetOptions xmlns="urn:schemas-microsoft-com:office:excel">
    <PageSetup>
    <Header x:Margin="0.3"/>
    <Footer x:Margin="0.3"/>
    <PageMargins x:Bottom="0.75" x:Left="0.7" x:Right="0.7" x:Top="0.75"/>
    </PageSetup>
    <Print>
    <ValidPrinterInfo/>
    <HorizontalResolution>600</HorizontalResolution>
    <VerticalResolution>600</VerticalResolution>
    </Print>
    <Zoom>85</Zoom>
    <Panes>
    <Pane>
    <Number>3</Number>
    <ActiveRow>13</ActiveRow>
    <ActiveCol>3</ActiveCol>
    </Pane>
    </Panes>
    <ProtectObjects>False</ProtectObjects>
    <ProtectScenarios>False</ProtectScenarios>
    </WorksheetOptions>
    </Worksheet>
    </Workbook>
    The report was designed to run on testcases, but I believe that any document type should work.
    When running it on an item with preconditions with no images, the result is the following (as excpected):
    <Workbook
    <Author>Anna Henke</Author>
    <LastAuthor>Anna Henke</LastAuthor>
    </ExcelWorkbook>
    <Table>
    <Cell>
    </Cell>
    <Cell>
    <Data ss:Type="String">Name: Printing </Data>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    <Cell>
    </Cell>
    <Cell>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    <Row>
    <Cell>
    </Cell>
    <Cell>
    <Data ss:Type="String">Single monitor setup is active</Data>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    </Table>
    <PageSetup>
    </PageSetup>
    <Print>
    <ValidPrinterInfo/>
    </Print>
    <Zoom>85</Zoom>
    <Panes>
    <Pane>
    <Number>3</Number>
    </Pane>
    </Panes>
    </WorksheetOptions>
    </Worksheet>
    </Workbook>
    This page displays nicely in excel:
    Excel - no images in descriptionRunning the report on a test case with images in preconditions results in the following - note, that "3D" is added all over the result file, for example:
    MIME-Version: 1.0
    This document is a Single File Web Page, also known as a Web Archive file. If you are seeing this message, your browser or editor doesn't support Web Archive files. Please download a browser that supports Web Archive, such as Windows® Internet Explorer®.
    --=3D_JAMA_BOUNDARY
    <?xml version=3D"1.0"?>
    <?mso-application progid=3D"Excel.Sheet"?>
    <Workbook
    xmlns=3D"urn:schemas-microsoft-com:office:spreadsheet"
    xmlns:o=3D"urn:schemas-microsoft-com:office:office"
    xmlns:x=3D"urn:schemas-microsoft-com:office:excel"
    xmlns:ss=3D"urn:schemas-microsoft-com:office:spreadsheet"
    xmlns:html=3D"http://www.w3.org/TR/REC-html40">
    <DocumentProperties xmlns=3D"urn:schemas-microsoft-com:office:office">
    <ExcelWorkbook xmlns=3D"urn:schemas-microsoft-com:office:excel">
    </ExcelWorkbook>
    <Worksheet ss:Name=3D"Scenario">
    <Table>
    <Column ss:AutoFitWidth=3D"0" ss:Width=3D"200"/>
    <Column ss:AutoFitWidth=3D"0" ss:Width=3D"547"/>
    <Column ss:AutoFitWidth=3D"0" ss:Width=3D"416"/>
    <Row ss:AutoFitHeight=3D"0" ss:Height=3D"18.75">
    <Cell>
    <Data ss:Type=3D"String">&nbsp;</Data>
    </Cell>
    <Cell>
    <Data ss:Type=3D"String">Name: 23_LOpPS_NLS Annotations </Data>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    <Row ss:AutoFitHeight=3D"0" ss:Height=3D"16.5">
    <Cell>
    </Cell>
    <Cell>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    <Row>
    <Cell>
    <Data ss:Type=3D"String">Preconditions:</Data>
    </Cell>
    <Cell>
    <Data ss:Type=3D"String"><span style=3D"color: rgb(0, 0, 0); font-family: arial, helvetica, sans-serif; font-size: 13.6000003814697px;">Note: English reference images serves as rough guidance only and might not be up-to-date.<br />
    <br />
    <strong>Image 1:<br />
    <img alt=3D"see attached image: 2014-12-12+11_04_19-syngo+SYNGO-VIA6.png" src=3D"cid:JAMA_IMAGE_15759.png" style=3D"width: 623px; height: 501px;" /></strong></span><br />
    </Data>
    </Cell>
    <Cell>
    </Cell>
    </Row>
    </Table>
    <WorksheetOptions xmlns=3D"urn:schemas-microsoft-com:office:excel">
    <PageSetup>
    <Header x:Margin=3D"0.3"/>
    <Footer x:Margin=3D"0.3"/>
    <PageMargins x:Bottom=3D"0.75" x:Left=3D"0.7" x:Right=3D"0.7" x:Top=3D"0.75"/>
    </PageSetup>
    <Print>
    <ValidPrinterInfo/>
    </Print>
    <Zoom>85</Zoom>
    <Panes>
    <Pane>
    <Number>3</Number>
    </Pane>
    </Panes>
    </WorksheetOptions>
    </Worksheet>
    </Workbook>
    --=3D_JAMA_BOUNDARY
    Content-ID: JAMA_IMAGE_15759.png
    Content-Transfer-Encoding: base64
    Content-Type: image/png
    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
