Issue doing batch transitions
  • 1.  Issue doing batch transitions
    Posted 11-22-2019 10:03
    In the screenshot above, you can see that a filter is applied and 127 items are selected, yet when I try to do a batch transition it ignores the filter and selection.
    Jonah Caplan
    QNX
  • 2.  RE: Issue doing batch transitions
    Posted 11-22-2019 11:36
    Hi Jonah
    Can you confirm for me that the items in your filter are the same item type? Are the items all in the same state? I'd also like to know if you received any error message. It doesn't sound like there was but just in case there was, could you attach a screenshot of the error?
    Thank you
    Godiva Hunt
  • 3.  RE: Issue doing batch transitions
    Posted 12-17-2019 01:36
    We have reported that 2 years ago, should be known as SOS-DEF-1644 and IMHO the bug SOS-DEF-2122 should also be related to that problem.
    Harald Hotz-Behofsits
    Frequentis AG
  • 4.  RE: Issue doing batch transitions
    Posted 12-17-2019 10:52
    Harald, thank you for this input.
    @Jonah if you could private message me your company info, I will relate your company to this defect : ​
    SOS-DEF-1644 where in search results only - When a user selects facets in a quick filter, then navigates to another Jama tab housing an item, and then goes back to the filter tab, the selected facets are do not persist and they have to filter again.
    I have already linked this thread to the defect item.
