Requirement deletion along with Relationship-related items
  • 1.  Requirement deletion along with Relationship-related items
    Posted 05-16-2017 09:05
    Edited by Dhinu Puthiyapurayil 05-16-2017 09:10
    Is it possible to delete a requirement along with all the Relationships - related items? Looking for a option where i can delete the parent requirement and subsequently all the Child requirements linked/with relationship to the parent also get deleted?
    Similiar to Reuse features, where we have option to to reuse along with relationship-related items or reuse as a single requirement?
    Thank you!
    Dhinu P
    Bose
  • 2.  RE: Requirement deletion along with Relationship-related items
    Posted 05-16-2017 12:14
    Hi Dhinu,
    There is no option that would wholesale cause the deletion of an upstream item to also delete corresponding downstream items. The easiest way to do this would be to create a filter than returns these "parent" items in question as well as the "children", using a couple different Conditions for upstream and downstream. At that point you could bulk delete from the filter results. Let me know if you have further questions on this.
  • 3.  RE: Requirement deletion along with Relationship-related items
    Posted 05-31-2017 03:10
    Thank you Kristina,
    Just another query regarding the same topic, Is it possible to bulk delete only the upstream Relationships/links based on specific filter?
    Thank you, Appreciate your assistance.
    Dhinu P
    Bose Automotive
  • 4.  RE: Requirement deletion along with Relationship-related items
    Posted 05-31-2017 10:59
    Hi Dhinu,
    It is not possible to delete relationships from a filter, only items. If you need to bulk delete relationships, you might consider using our REST API to write a script (e.g. DELETE /relationships/{relationshipId}).
