Diagram Editor in Jama 8.10.x works with XMI file?
  • 1.  Diagram Editor in Jama 8.10.x works with XMI file?
    Posted 01-25-2017 03:27
    is that possible using Diagram Editor in Jama 8.10.x to open and edit a diagram was stored as XMI file (Diagram was exported from Sparx EA)?
    Lien
    Lien Bäcker
  • 2.  RE: Diagram Editor in Jama 8.10.x works with XMI file?
    Posted 01-25-2017 11:33
    Hi Lien,
    No new capabilities have been introduced in the Diagram Editor with 8.10. There is a workaround for editing diagrams in Jama's editor if you can access the source XML from the diagram file. If you check out an article Adrian wrote, there is a video that walks you through it.
  • 3.  RE: Diagram Editor in Jama 8.10.x works with XMI file?
    Posted 01-26-2017 00:54
    I have seen the Video and the artical from Adrian. Muss the XML code be with <mxGraphModel>? The Content of XMI is written with other type. Does your Team have some experience with coping XMI file to the souce code of the diagram? Any walkaround?
    Lien
    Lien Bäcker
  • 4.  RE: Diagram Editor in Jama 8.10.x works with XMI file?
    Posted 01-26-2017 02:17
    The use case is: an extend Partner prepares the use case in Sparx EA. Can we somehow edit the "exported" use case out of Sparx EA within Diagram Editor of our Jama? Anything our Partner should take note by exporting as such the exported use case can be opened and editted by Diagram Editor of Jama?
    Lien
    Lien Bäcker
  • 5.  RE: Diagram Editor in Jama 8.10.x works with XMI file?
    Posted 01-26-2017 15:59
    Lien, I do not have a workaround for this particular standard you are using. I am checking in with some consultants here to see if they have solved this issue with any other customers. I will let you know if they can provide a workaround.
