Export templates with Test Run steps in a table
  • 1.  Export templates with Test Run steps in a table
    Posted 02-08-2017 14:39
    I want to export my test runs with the steps printed in a table. I've done this before with requirements using the mail merge format:
    <<TableStart:CHILDREN:REQ>>
    How do I do this with test run steps?
    Can comments also be tabulated in mail merge exports?
    DeAnn
  • 2.  RE: Export templates with Test Run steps in a table
    Posted 02-08-2017 15:30
    Hi DeAnn,
    If you download the System Test Procedure book from our user-created library, you'll see an example of a way to include test steps in a table. Essentially you need to put each test case step field in a cell. See page 7 of the template.
    As far as comments go, there is no way to perform any mathematics in the export to provide a tabulation.
