Previous Baseline Select Component Export
  • 1.  Previous Baseline Select Component Export
    Posted 06-24-2020 18:05
    I created a baseline of my requirements a few revisions ago.
    I would like to export a subset of that baseline.
    How would this be accomplished ?
    I can display the baseline but it contains more information than I want.
    The project consists of 3 components.
    I only want 1 of the components.
    Thanks.
    William Hayes
    Aerovironment
    Simi Valley CA
    +1-805-581-2198 x1860
  • 2.  RE: Previous Baseline Select Component Export
    Posted 06-25-2020 10:07
    I'd also very much like to know this, we have reports tailored for particular components, but would much rather just baseline the whole project at milestones than each individual component.
    On a related note, it would great if there was a way of viewing a baseline in the navigation tree instead of just flat. Essentially a way to view a project as it was at a baseline in a sort of read-only mode.
    Rafael Medina
    ON Semiconductor
  • 3.  RE: Previous Baseline Select Component Export
    Posted 06-29-2020 07:33
    Willam and Rafael:
    I asked around about this and the best we could think of is playing around with a custom report that takes a component ID as a text input. Then you would have to type in the id of the component you want exported and select the baseline they want to export from a list. But, I have been advised that there isn't a solid way to do this which will work for every instance 100% of the time.
    Happy experimenting, and let us know if this works for you!
