Hi Scott -
If you have access to either of the Baseline Comparison Reports that come with your Jama instance, they have code that can help you get the information you need. If you have an on prem instance, you can go to Admin > Reports, find one of the reports, go to Edit File and copy the code that appears in the window. Paste that code to a different Text editor and you can look at the code and see if you can find the information you need. If you are a hosted customer (the url to your instance has .jamacloud in it), you can ask Customer Care to help you with that.
Shawnna Williams
Professional Services Engineer
Shawnna Williams
Sent: 01-31-2019 12:29
Subject: Velocity & Baselines
I would like to write a report that exports baseline information and set attributes from a baseline to excel. I can use a report parameter to access the baseline but I'm struggling to access the list of documents in the baseline to loop through and export. Is there documentation to help me understand how to do this or better still example velocity code?
Thank you for your help.
Scott Rocca
Collins Aerospace
Malvern
