convert sub requirement to full requirement
  • 1.  convert sub requirement to full requirement
    Posted 14 days ago
    I mistakenly added some requirements as sub requirements. I cannot seem to find a way to promote them up a level.
    I searched here and found the instructions for sub item to item. But it did not work, after clicking on the sub item key, and then using convert to requirement, going through all the warnings on what might get deleted, when I finally hit convert it asks me for to select a location. But they are grey'd out and it tells me they are not a valid location.
    Any help is appreciated.
    Eric Flachbart
    Infusion Analytics
    Riverview FL
    8027519209
  • 2.  RE: convert sub requirement to full requirement
    Posted 14 days ago
    Hi Eric,
    Thank you for reaching out! I know I've replied to you directly regarding this question but I want to answer you in this thread as well.
    If the sub requirements are child requirements, you will need to view them in a full list view (of the set or folder) and select them and drag them to the highest level container that you want them in. They will then be the same level as the other requirements, just below them in the tree.
    I hope this information helps! Please reach out if you have any questions.
    Decoteau
