Actually that's what I did, I created filter for all passed Test Runs, and send them to Review Center.
The Idea of adding custom field is perfect, I will propose this solution to our team.
Thanks for the reply, it is very helpful.
Have a nice day,
Sawsan
Sawsan Abusharkh
Sent: 02-14-2017 14:32
Subject: Review test plan
Hi Sawsan,
Test Runs are an interesting sort of item type, and you will occasionally run into limitations; in this case, you cannot use any sort of Workflow with them.
There is not an automated way to send Test Runs to the Review Center. What I recommend is adding a custom field to the Test Run type, such as "Review Status," with values such as "Unexecuted" "Ready for Review" and "Reviewed." You would have to train users to update this field after executing the test run. You could then build a filter for Test Runs with the Ready for Review status and then send the filter results to review.
Sent: 02-14-2017 04:01
In our project there is a test run that was successfully completed.
Is there a way to set up a workflow for someone to review and approve this executed test run (in review center)?
We would like for a technical reviewer to approve each executed test case so they may be reviewed for accuracy.
Sawsan
Sawsan Abusharkh
