Hi
@Anna,
for Testcases this works perfect because each TestRun item has a field TestCaseVersion.
But for regular items (like system requirements), this field does not exist and even the workaround
@Theresa mentioned does only show when the suspect was cleared (to: false from: true), not the other way round.
I will check on the EventLogDao etc if there is a possibility.
Thank you so far.
@ChloeOur use case is that our tester have testscripts/testcases linked to system requirements.
If somebody changes the system requirement, the tester must check if his script is still valid, so he/she must know what change of the upstream item caused the suspect.
Right now the only thing I see is that a relationship IS suspect, not when. So it is possible that it was set 1 day ago or half a year ago.
Sebastian
Requirements Engineer
Sick AG
Sent: 12-05-2019 04:21
Subject: Date/Version when suspect was set
We had the same problem here.
We have not been able to solve this through what Jama offers, but have written a velocity report that evaluates the traces between items and circles back in the versions of the items to check if a test was "valid" at a certain date.
We use this when creating our testreports - if this would be a feasible workaround I would check if I can extract that from our velocity code...
Anna Henke
Sent: 12-04-2019 12:36
Yes! This will be a problem for us too.
The only help I've found is to search the project Activity Stream for "suspect." This will bring up events like "Suspect changed to: "false" from "true"", and the event information includes a date. Then you need to match the date with the requirement version in the version history widget. I have investigated getting this information through the EventLogDao and EventEntry in Velocity, but I don't think I finished. If you decide to try this and are successful, I'd love to know about it.
Theresa
Fujifilm SonoSite
WA United States
Sent: 11-21-2019 09:20
Hi Guys,
is there an update to suspect post?
We are faced with the problem that we have a lot of suspect relationships between specification and verification items and our testers want to know if their tests are still valid for the requirements.
So is there ANY technical solution how we can identify the version of the requirement (upstream item) when the suspect flag was set?
For the testruns it works (in velocity) with getTestCaseVersionNumber() but for regular relationships I could not find any suitable solution.
This really bothers us because it causes a lot of work.
Sebastian
Sick AG
