Calculated Date Fields
  • 1.  Calculated Date Fields
    Posted 06-13-2019 04:15
    I have the situation where a user can set a field on a requirement and this triggers some other software to replicate that requirement within a JIRA project.
    This works well.
    I'm now trying to solve a problem where I want to be able to identify objects in JIRA which are no longer being controlled from JAMA.  Essentially where a user in JAMA might set this export field to 'JIRA-ABC' one day, this results in a replicated requirement in JIRA project ABC, but then subsequently changing this field to JIRA-XYZ, resulting in a new replicated requirement in JIRA project XYZ.
    I want to be able to identify the requirement in JIRA project ABC.
    After some thought I think I can achieve this by having a field on my JAMA requirements which is always the current date / time.  I would then be able to sync this across to JIRA and I could achieve my goal by simply querying objects where this field is not within a few minutes of current date and time.
    My problem is that I cannot see a way to include this date field and have it auto populated?  Is this achievable please?
    Andy
  • 2.  RE: Calculated Date Fields
    Posted 06-13-2019 11:43
    Andy:
    A couple of questions:
    What version of Jama are you using? And are you using Tasktop or OpsHub?
  • 3.  RE: Calculated Date Fields
    Posted 06-13-2019 13:24
    Hi Chloe - I'm using Jama Connect 8.31.2 and Tasktop.​
    Andy
  • 4.  RE: Calculated Date Fields
    Posted 30 days ago
    Hi Andy,
    You could add the "ModifiedDate" field to the Jama item and have Tasktop sync it to a field in Jira. This would let you know when the field was changed to JIRA-ABC in Jama when you look at the items in Jira.
    Hope this helps,
    Jason Ritz
  • 5.  RE: Calculated Date Fields
    Posted 28 days ago
    Hi Jason,
    I think this could only work if the objects in Jama were subjected to regular updates.  The reality is they might only be updated periodically.
    I suppose this could be overcome by doing a bulk update once in while which would update the modified value of all artefacts.  Is there a quick and easy to do this?
    Andy.
    Andy
  • 6.  RE: Calculated Date Fields
    Posted 28 days ago
    Andy:
    There is a batch update option within the list view: Batch Update Items.
    You can also manually update items within the list view: Edit Items In The List View.
    Note: You cannot batch update rich text fields and you cannot use this method to batch update test runs.
  • 7.  RE: Calculated Date Fields
    Posted 27 days ago
    Hi Chloe,
    Ah perfect.  I didn't know about that batch edit feature.  That will work perfectly.​
    Many thanks for your help.
    Best Regards,
    Andy.
    Andy
