Export fields on demand
  • 1.  Export fields on demand
    Posted 08-29-2018 11:11
    I have a template that includes several field template definitions (see template fields below). However, when I export, it doesn't matter what I have selected for display in list or reading view -- my output always matches exactly what is shown in the template (e.g. if I set up list view to show my stakeholder requirement item type, and I include fields like "Priority" and "Risk", they show up in reading and list views, but when I export, the document only shows name, document key, and description.
    Is there any way to fix this? I am pretty sure there was a time when export included any fields that were displaying in list view.
    «TemplateStart:DEFAULTTEMPLATE»
    «TableStart:HEADING»
    «name» («documentKey»)
    «TableEnd:HEADING»
    «description»
    «TemplateEnd:DEFAULTTEMPLATE»
    «TemplateStart:SET»
    «name»
    «TableEnd:HEADING»
    «description»
    «TemplateEnd:SET»
    «TemplateStart:FLD»
    «name»
    «TableEnd:HEADING»
    «description»
    «TemplateEnd:FLD»
    «TemplateStart:CMP»
    «name»
    «TableEnd:HEADING»
    «description»
    «TemplateEnd:CMP»
    «TemplateStart:TXT»
    «name»
    «TableEnd:HEADING»
    «description»
    «TemplateEnd:TXT»
    «TemplateStart:STK»
    «TableEnd:HEADING»
    «description»
    Rationale:«rationale»
    «TemplateEnd:STK»
    Spencer
  • 2.  RE: Export fields on demand
    Posted 08-30-2018 12:25
    Hi Spencer,
    Could you please confirm if you are adding the fields to be visible in the list view of Jama and not only through the Admin > Item types > Views method?
    Dana Medhaug
    Technical Support Engineer
  • 3.  RE: Export fields on demand
    Posted 08-31-2018 10:26
    Edited by Spencer Bondhus 08-31-2018 10:26
    Correct. See the two images below.
    Spencer
  • 4.  RE: Export fields on demand
    Posted 08-31-2018 10:47
    Hi Spencer,
    Is it possible for you to attach your report? I would like to look at it in Word. Thank you.
    Dana Medhaug
  • 5.  RE: Export fields on demand
    Posted 09-04-2018 08:13
    Our default word export template is attached, as is the sample export I pasted a picture of in my post above.
    Spencer
    Attachment(s)
    doc
    Flavor.doc   193K 1 version
    doc
    FM0514_JamaDefault.doc   332K 1 version
  • 6.  RE: Export fields on demand
    Posted 09-05-2018 20:50
    Hi Spencer,
    I'm still studying this and I wanted you to know I have not forgotten about you. I'll check back when I have an update. Thank you for your patience.
    Dana Medhaug
  • 7.  RE: Export fields on demand
    Posted 09-06-2018 10:48
      |   view attached
    Hi Spencer,
    I found that when I toggled the field codes in your template some (quite a bit) were not correct, as an example when I toggled
    «TemplateStart:SET» it was actually {MERGEFIELD TemplateStart:FLD\* MERGEFORMAT}. Could you try the attached doc and see if you have better results? Thank you.
    Dana Medhaug
    Attachment(s)
    doc
    spencer_merge.doc   332K 1 version
  • 8.  RE: Export fields on demand
    Posted 09-11-2018 13:22
    I see what you're talking about. I tried your file, and it still doesn't seem to affect the output.
    Spencer
