Programatically Update Test Cases Result in Jama from Jenkins
  • 1.  Programatically Update Test Cases Result in Jama from Jenkins
    Posted 06-13-2018 01:54
    We have a test automation in place which gets triggered from the Jenkins on one server.
    We get the consolidated report of the TC's result in the jenkins.
    Our CTQ is how do we link these test results back to Jama's Test run?
    Is there any way, by which we can update the TC's result in jama?
    Thanks & Regards,
    Shahajahan
    Shahajahan Sheikh
    Hon
    Hyderabad IN
    9989787311
  • 2.  RE: Programatically Update Test Cases Result in Jama from Jenkins
    Posted 06-15-2018 15:37
    Hi there Shahajahan,
    Thanks for reaching out here with this Test Center's results in Jama.  Are you currently using any of Jama's API calls to navigate this information between Jenkins and Jama?  I ask because I'm thinking that you may be able to use the PUT request with the "/testruns/{id}" endpoint to make updates as needed, but am wondering if you're already doing this or not.
    If you'd like to learn more about this, I'd recommend reviewing our API documentation via this link, and seeing if any of those other endpoints will work for your needs here.
    And of course, let me know if you have any more clarifications or questions.
    Nick S
  • 3.  RE: Programatically Update Test Cases Result in Jama from Jenkins
    Posted 06-15-2018 15:48
    Hello Shahajahan,
    The best way of accomplishing the task at hand would be to obtain OpsHub Integration Manager (OIM), our official integration partner. To learn more about OpsHub, please consult this article. If you would like to find out more details about this offering from Jama please contact your Account Manager.
    The second option is to leverage our API. Please learn more here.
    Getro Naissance
