Hi all!
we are want to start our first Jama-Project in a few weeks.
Actually we have a few documents that we want to import in Jama (Jama Version 4.0).
All Documents has the Word-Format of .docx or .doc
now i have a few design Problems.
At first a few documents includes some math symbols (Word Forumlar-Editor). These symbols are not supported in Jama and it will be added as a Image (if you import the Word-File). Is there a usefull solution that allowes to write math-symbols or functions in Jama when you edit a Item? Pasting the Word-Text into the Jama-Item is not working.
Well its not only a import Problem. It is a main Problem when we want to switch fully into Jama.
e.g.:
The second Problem is the usability of orginal pirctures/images.
If we import some Images from Word it resize it. So after we export it again with a template a second manually resize is need to be done.
Is there a best practice to handle pictures? or something simliar?
Well i hope you guys could help me, that would be great!
Thanks a lot!!
- D -
