Different user lists depending on item edit mode
  • 1.  Different user lists depending on item edit mode
    Posted 10-17-2018 04:06
    Dear Jama community,
    Depending on the selected mode to edit an item, the list of shown users for a field of type "User" is different - we use Jama hosted solution  :
    1) "Edit item" button in upper right corner: The list of users is restricted to users that have access to the project
    2) "Pencil next to field": The list of users seems to contain all Jama users, i.e., no restriction on project-level
    Is this behaviour a known Jama issue?
    Many thanks, Alexander
    Alexander Bergmayr
  • 2.  RE: Different user lists depending on item edit mode
    Posted 11-19-2018 13:47
    Hi Alexander,
    Thank you for bringing this issue up. There was a defect created for this (SOS-DEF-777) but due to the limited impact, the defect has not been fixed as of yet.
    Dana Medhaug
    Technical Support Engineer
