Baselining Test Plan and Test Cycle/Test Runs
  • 1.  Baselining Test Plan and Test Cycle/Test Runs
    Posted 06-30-2021 04:34
    For our project needs we need to baseline all test related items. This is quite simple for test specification (test cases), but there doesn't seem to exist an elegant way to do this for Test plan and Test Cycles/Test Runs.
    Our current way of doing it (workaround) is to send Test plan/Test Cycles/Test Runs for review and trigger the baseline with the review. However, this approach has multiple problems:
    1. Minor: uneeded reviews are created
    2. Moderate: Many small baselines are created instead of few larger, more logical that contain whole set of information within one baseline
    3. Major: Can not have Test cases and Test plan in same baseline
    Is there a better way to baseline this?
    Vinko Šurija
    Rimac Automobili
  • 2.  RE: Baselining Test Plan and Test Cycle/Test Runs
    Posted 06-30-2021 07:15
    Hi Vinko,
    I normally use advanced filters for this.
    Just select the desired items and then generate a baseline using the filter as source.
    Hope it helps ...
    Best Regards,
  • 3.  RE: Baselining Test Plan and Test Cycle/Test Runs
    Posted 06-30-2021 14:46
    Hi Vinko,
    Thanks for reaching out! I wanted to write and confirm that Alessandro's suggestion of manually creating a baseline off of an Advanced Filter is a great suggestion.
  • 4.  RE: Baselining Test Plan and Test Cycle/Test Runs
    Posted 07-12-2021 05:52
    Hi all,
    Thank you for your answers. This helped me.
    Best regards,
    Vinko Šurija
    Rimac Automobili
