Revision field not imported from an exported JAMA spreadsheet
  • 1.  Revision field not imported from an exported JAMA spreadsheet
    Posted 24 days ago
    I have used the 'Export to Excel' option from JAMA for exporting Test Run results and using the same spreadsheet for creating new test cases and import back. When completing the import, the 'Revision' field is not imported - it stays blank even if the number is there. I have tested the same scenario with an excel spreadhseet generated outside of JAMA and it is working.
    Can you check why is this? Files is use are attached. FYI the same TC's are in both files.
    Lilliana
    Lilliana Feliciano
    Siemens
    Minnetonka MN
    Attachment(s)
