own Text item type
  • 1.  own Text item type
    Posted 12-03-2018 04:53
    Hi Guys,
    I was wondering if it is possible to create an own text item type (we use Jama 8.20.2)?
    As far as I can see, Text, Test Cycle, Test Plan, Test Run and Folder can only be editted but no own type can be added- is this intended?
    We are planning to use own jama project to specify 3 different (but quite similar) variants.
    Thus, I created a new specification item type extended by a field "Device Variant" which is a multi-select picklist for Variant A,B and C.
    Unfortunately, I cannot create an own text item type so I cannot see a good possibility to create a text element which is only for variant A.
    The only workaround would be to name the text/folders like the variants- which is very error-prone.
    Thank you for your thoughts and best regards,
    Sebastian Merz
    Requirements Engineer
    Sick AG
  • 2.  RE: own Text item type
    Posted 12-03-2018 06:57
    Sebastian,
    Unfortunately you do not have the ability to create a 2nd Text Item type. For variants there can be many solutions, so it would be best for us to have a conversation about this. I have reached out to you separately to discuss.
    Matt
    Matt Mickle
