Hello Chloe,
Yes, I'm using the Single Item view.
And the issue is that I'm not able to configure the exported fields...
I attached a screenshot of an export.
I want to add additional fields in this export, in my example, I want to export Test Steps and avoid using Office Template.
But it seems there's no parameter available regarding this Export to Word feature.
Regards,
Mathieu.
Mathieu
Sent: 11-14-2019 11:39
Subject: Item - Export to Word - Fields ?
Hello Mathieu:
Thank you for posting in the Community! Can you tell me, which fields are excluded in the Export and which are included, in this case? And can you confirm that you are attempting to export from within a Single item?
Sent: 11-13-2019 04:53
When I'm on a specific item, I can click "Export" > "Exporto Word", but, when doing this from a specific item don't let me export all the needed fields.
How can I configure this export?
I know of to configure the Reading view and List view to select the needed fields, but how to do this when I'm in a specific item ?
Regards,
Mathieu.
Mathieu
