Hi Mike,
I didn't find any easy way to get the Jama version is via REST in 8.10 either, using a specific API call or just looking at the headers.
A GET request to /rest/ will contain Jama's build date:
{"meta":{"status":"OK","timestamp":"2017-02-14T20:28:35.249+0000"},"data":{"buildDate":"2017-02-01T13:37:00.000+0000","apiVersions":[{"description":"initial REST API product","uriSegment":"v1"},{"description":"latest API version: initial REST API product (v1)","uriSegment":"latest"}]}}
Which will change with each version of Jama.
It's not a great solution (for obvious reasons), but I'd be tempted to do a GET request for Jama's login page and scrape the version number off that.
Jason Short
Sent: 02-13-2017 16:25
Subject: Ability to determine Jama version via REST?
Does the REST API offer any method to determine the Jama version? I ask because we have ~6 instances of Jama for Production purposes and each Production instance is backed by at least one pre-production instance. The versions on those instances can sometimes get out of sync, and today we have some pre-production instances on 2015.1 and some production instances on 8.4.1 while others are 8.4.2. However, for all instances, the REST API is always .../rest/latest/.... As the REST API improves and evolves over different versions, it would be helpful to know what version the automation using REST is communicating with in order to take optimal advantage of the available calls. For example, if we end up with a mix of 8.4, 8.10, and 8.14, it would be helpful to know that user groups cannot be created in 8.4, and that the PATCH endpoint and Read Only field updates are not available in 8.10.
I did not see anything in our current (8.4.1) REST calls or in the response headers that would help determine the Jama version, but would be happy to be corrected on this if I missed it.
Mike
Nobody will ever win the Battle of the Sexes. There's just too much fraternizing with the enemy. ~Henry Alfred Kissinger
