Headings in Word Export
  • 1.  Headings in Word Export
    Posted 11-13-2017 12:54
    I have a design specification template which looks like the following:
    «TemplateStart:DEFAULTTEMPLATE»
    «TemplateEnd:DEFAULTTEMPLATE»
    «TemplateStart:TXT»
    «description»
    «TemplateEnd:TXT»
    «TemplateStart:FLD»
    R #
    Global ID #
    Requirement
    Source
    Verification
    «description»
    «TemplateEnd:FLD»
    «TemplateStart:DS»
    «qw_identifier»
    «globalId»
    «requirement»
    «description»
    «source_naritive»
    «TableStart:UPSTREAMRELATIONSHIPS»«qw_doc»«name»«TableEnd:UPSTREAMRELATIONSHIPS»
    «TableStart:RELATIONSHIPS»«name»«TableEnd:RELATIONSHIPS»
    «TemplateEnd:DS»
    The highlighted description field is what I am having some trouble with. This field is pulling from the folder description, and is formatted as Heading 2 in the Word template.
    When I export using this template, I get the following:
    R #
    Global ID #
    Requirement
    Source
    Verification
    1.1  General Requirements
    1.2
    I can't figure out why I am getting the second highlighted heading number, and I'm not sure what else to investigate.
    Advice?
    Patricia
    BioFire Diagnostics
  • 2.  RE: Headings in Word Export
    Posted 11-14-2017 09:09
    Hello Patricia,
    Is it possible for you to attach the Word doc here so I can take a look at it? Thank you.
    Dana Medhaug
    Technical Support Engineer
