Navigate between tabs reset filters.
  • 1.  Navigate between tabs reset filters.
    Posted 07-25-2018 01:09
    Some of my colleagues encounter a disagreeable behavior when navigating between JAMA tabs.
    In the items List view, we can setup filters:
    thumbnail image
    And when we click on an Item a new JAMA tab opens:
    thumbnail image
    But if we go back to the previous tabs where our filters are defined, the tab will be refreshed and our filters reset:
    thumbnail image
    What can we do to avoid this behavior ?
    Regards,
    Mathieu
  • 2.  RE: Navigate between tabs reset filters.
    Posted 07-31-2018 16:14
    Mathieu:
    I can see how this would interrupt your workflow. This is a known bug where the filter from search results, selected facets do not persist in a filtered view if the user views another Jama tab. The workaround at this time is: to build an advanced filter.
    This bug has been logged in our internal system with this Community Post associated with it. For your reference the bug ID is: SOS-DEF-1644. You can check future release notes for this ID to see if this bug has been fixed. I can tell you that this particular bug has been chosen to target in a sprint!
    If you have any questions about our bug fixing process, I recommend reading this article in our community.
    Business Support Engineer
