Theresa:
Nice catch, with the new release of the New User Guide this past May, a lot of these past links have broken! Thank you for your contribution.
Business Support Engineer
Sent: 06-19-2018 17:22
Subject: Questions and requests about searching the community
Hi Getro and all -
FYI, the "Search tips" link Getro posted takes me to the root of the User Guide. I found a page of Search tips here.
Theresa
Fujifilm SonoSite
WA
Sent: 03-14-2018 19:02
Hi Daniel,
It turn out we already have a "Search Tips" Section in the User-guide. Higher Logic uses Lucene syntax (which is what our elastic search syntax is based off of). Hence, since the community uses the same syntax, please consult the link below to learn more about searching tips. The only difference is you would not have the ability to search fields, since that isn't a concept in the community platform
Search tips
Getro Naissance
Sent: 03-07-2018 14:43
I have been using the community to try to find answers to my questions. I am finding searching it somewhat challenging, both because of the lack of instructions and behavior that I cannot explain.
- How to search in the community
- I could not find instructions on how to create advanced or complex searches. For example, if I would like to search for the phrase "main column" is this what I would put in the search field, or would I have to use single quotes, or is this not possible?
- By trial and error I found that I could use the keyword and.
- Please consider creating a link to some simple instructions on how to create advanced searches, what syntax is supported, etc.
- Weird results when I search for "main column"
- When I tried searching for "main column" (including the quotes) I got five results.
- One of the results was: "Topic: Synchronization doesn't handle deleted items", here is link: https://community.jamasoftware.com/communities/community-home/digestviewer/viewthread?GroupId=7&MID=187&CommunityKey=4eac21f6-24d1-4f1e-92bd-76860b52af2c&tab=digestviewer
- I'm not sure why this result came up. The word 'main' was not there and the word 'column' was. The word 'column"' (i.e. column with a closing quote) was not there. Searching for "main column" (no quotes) yielded 350 results, so that isn't what was happening.
- Once again, perhaps some instructions would be helpful.
- Please expand the capabilities of search to be able to look for phrases in addition to the Boolean operators
Thank you.
Daniel
