Export all items in a baseline
  • 1.  Export all items in a baseline
    Posted 02-09-2017 02:10
    Edited by Lien Bäcker 02-09-2017 04:19
    Can user export all items of a baseline (with desription and Name) + information about the baseline itself (signatures, description from baseline) using the Default Word template?
    I have tried it (with 2015.2)...
    - create a baseline with only one item type (2 items in a set)
    - select view baseline (I can see all items in reading view)
    - click Export to word
    the Report runs but never find an end.
    In oder to do this Export, what should I do?
    Lien Bäcker
  • 2.  RE: Export all items in a baseline
    Posted 02-09-2017 12:16
    Hi Lien,
    Yes, your user should be able to export the baseline items via the default Word template. However, the only things that will export are the items themselves—the Word export is only going to show what's in reading view, so the signature and baseline details are not included.
    As far as the report never finding an end, I just double-checked this on 2015.5 and 8.12 and there doesn't seem to be any problems to do this. The first thing I'd be curious about is your default Word template—do you have issues exporting any other views with it? If not, then the best course of action would be to submit a ticket to support so we can look at your logs and see if there is some sort of exception. From your description of the baseline it doesn't sound like it'd be so large it times out.
