Created unreadable Verification Test Case item using Jama API
  • 1.  Created unreadable Verification Test Case item using Jama API
    Posted 09-16-2021 14:04
    I am using Jama API to add automatically Verification Test Case items to our Jama project. It looks like I messed up with the Jama API parameters some how. I have created items that I cannot read, change, and delete. Every time I click on the created items, the Jama engine returns a message:
    This message I received trying to open a Verfication Test Case item
    Do you have any suggestion how I can fix this problem?
    We are using Jama Connect - Build date: 2021/08/05 09:28 -
    Mikhail Vassiliev
    Mikhail Vassiliev
    Irdeto
  • 2.  RE: Created unreadable Verification Test Case item using Jama API
    Posted 28 days ago
    Hi Mikhail,
    Thank you for reaching out! This issue seems like it'd be best suited for a direct Support ticket.
    Can you open a Support ticket HERE and start the ticket by confirming if you're using (or used) a PUT call after the POST call to create the items?
