How to export test run results
  • 1.  How to export test run results
    Posted 08-31-2018 14:53
    I am trying to make a report of all test runs within a test cycle that contains:
    1. The test run name and details
    2. Steps for each test run
    3. Step action
    3. Expected result for each step
    4. Notes for each step
    5. Results for each step
    I have not figured out how to export the result for each step into a table. I expected the template to look something like this:
    «TemplateStart:TSTRN»
    «TableStart:STEPS»
    «stepIndex»
    «action»
    «expectedResult»
    «notes»
    «results»
    «TableEnd:STEPS»
    «TemplateEnd:TSTRN»
    The last column of the table doesn't give the results of the test like I had hoped, it just repeats the previous column.
    Is it possible to create a template like this when exporting test runs?
    Alex Wiitamaki
    Appareo
    Fargo ND
  • 2.  RE: How to export test run results
    Posted 09-06-2018 09:58
    Hi Alex -
    Which version of Jama are you using? We have 8.25 and this behavior works for us.
    Here's my Office template:
    Step Index
    Action
    Expected Result
    Notes
    Status
    Result
    «TableStart:STEPS»
    «stepIndex»
    «action»
    «expectedResult»
    «notes»
    «status»
    «result»
    «TableEnd:STEPS»
    And here is the output (steps 1-4 omitted for clarity):
    Step Index
    Action
    Expected Result
    Notes
    Status
    Result
    5
    Go to More à System Settings àConnectivity. Select DICOM Setup. Select Config button then Location. Select New and attempt to enable/disable the Wireless check box.
    Verify the Wireless checkbox can be set to enabled or disabled.
    SRD10682
    Passed
    Some text in Test Step Result
    Does this help?
    Theresa
    Fujifilm SonoSite
    WA United States
