And one more question related to topic issue:
What is the
bad\problematic point in next structure?:
I have test cases. I reuse them a few times so clones will get other IDs.
After that I put those test cases to different groups of one TestPlan. The groups will: Windows, Linux, Unix etc. Every group will contain exactly same set of testcases.
After that I will can run related to environment group.
For example, for windows I will run group "windows". Etc.
If I will change some test case, all reused from it testcases will updated.
So I will have 1 Test Plan and a few groups of test cases according tested environment.
Yana Fridman
ZAC
Sent: 01-11-2018 11:56
Subject: Same tests for multiple environments
Ok, understood. Thank you!
Yana Fridman
ZAC
Sent: 01-11-2018 05:01
Ok, thank you both a lot.
I have no experience with jama, it is new framework for me.
But explain me please :
If I will use in Cycling - is it not more UNcumbersome method?
I mean: 1 Test plan and different cycles (signed by different tags) for different OS environment
Yana Fridman
ZAC
Sent: 01-10-2018 12:16
Hello Yana,
I agree with @Harald his suggestion makes a lot of sense and it might be the less cumbersome method of achieving this.
Dana Medhaug
Technical Support Engineer
Sent: 01-08-2018 11:53
Probably can also do next:
Reuse test cases. Reused TC will get other GlobalId. After <g class="gr_ gr_201 gr-alert gr_gramm gr_inline_cards gr_run_anim Punctuation only-ins replaceWithoutSep" id="201" data-gr-id="201">that</g> I will <g class="gr_ gr_200 gr-alert gr_gramm gr_inline_cards gr_run_anim Grammar replaceWithoutSep" id="200" data-gr-id="200">can</g> add them to same TestPlan, different groups. It will be exactly same TestCases but with different IDs (reused). And I will <g class="gr_ gr_195 gr-alert gr_gramm gr_inline_cards gr_run_anim Grammar replaceWithoutSep" id="195" data-gr-id="195">can</g> add groups: Windows, Unix etc in one TestPlan. Under those <g class="gr_ gr_199 gr-alert gr_gramm gr_inline_cards gr_run_anim Punctuation only-ins replaceWithoutSep" id="199" data-gr-id="199">groups</g> I will add those reused TestCases.
Correct?
But this way (and separate Test Plan for each environment) will multiple data. Or in TestPlans, or in TestCases. I like the way without multiple data. So it is cycling. What wrong <g class="gr_ gr_207 gr-alert gr_gramm gr_inline_cards gr_run_anim Grammar multiReplace" id="207" data-gr-id="207">in</g> it?
Yana Fridman
ZAC
Sent: 01-08-2018 09:53
I would create a <g class="gr_ gr_185 gr-alert gr_spell gr_inline_cards gr_run_anim ContextualSpelling ins-del multiReplace" id="185" data-gr-id="185">testplan</g> for each different environment. A test is only passed when all instances in the different environments are passed.
Harald Hotz-Behofsits
Frequentis AG
Sent: 01-07-2018 09:26
What is the best way to organize test runs on multiple environments (for example Windows, Unix, Linux etc)
What will be correct:
- To create separate TestPlan for each environment by duplicate origin TestPlan
- Or use in different run cycles (for different environments) and add related different tags to those cycles. <g class="gr_ gr_211 gr-alert gr_gramm gr_inline_cards gr_run_anim Style multiReplace" id="211" data-gr-id="211">Like :</g> Cycle 1 run on Windows and have tag Win, Cycle 2 run on Unix and have tag Unix etc.
- Or some other way?
Yana Fridman
ZAC
