Deleting a Test Cycle does not Delete the Test Runs
  • 1.  Deleting a Test Cycle does not Delete the Test Runs
    Posted 04-12-2019 18:25
    ​Hello,
    If I select a test run ID from the Test Run view, I have the option to delete the test run, however, If I try to delete a Test Cycle, the Test Runs from the cycle are not deleted. Is this the correct behavior? If so, is there another way to remove the test runs that were not deleted after removing the cycle?
    I'm stuck now with that issue now.
    Lilliana Feliciano
    Siemens
    Minnetonka MN
  • 2.  RE: Deleting a Test Cycle does not Delete the Test Runs
    Posted 04-12-2019 18:34
    Please disregard this issue. Seems like our server was not updating as it should. All test runs were removed from the Test Run view after deleting the Test Cycle.
    Regards, Saludos
    Lilliana
