Insert Tab in Rich Text Field
  • 1.  Insert Tab in Rich Text Field
    Posted 15 days ago
    Hi - How do I insert a tab character in a rich text field.  Thanks.
    Andrew Collins
    Meteorcomm LLC
    Renton WA
    2538722521
  • 2.  RE: Insert Tab in Rich Text Field
    Posted 13 days ago
    Hi Andrew,
    Thanks for reaching out! There is an "Increase Indent" feature that current exists in our Rich Text editor called "Increase Indent" which acts as a tab insert.
    I have attached a screenshot below showing the area.
    Does that feature work for what you're looking for?
  • 3.  RE: Insert Tab in Rich Text Field
    Posted 13 days ago
    Hi Decoteau – This indents the whole line.  An example probably helps:
    •           An item             // A comment
    •           Another             // Another comment
    •           A third item       // A third comment
    Or in Word with hidden characters showing:
    Interestingly, copying and pasting from Word to Jama replaces tabs with spaces.
    Using tabs, the comments above can be nicely lined up without having to type in spaces (which only works well for monospaced fonts)
    An alternative would be to have a table with no visible borders but this would be tedious.
    Andy
  • 4.  RE: Insert Tab in Rich Text Field
    Posted 13 days ago
    Hi Andrew,
    Thank you for the example.
    Though MS Word allowed you to copy that formatting over, our Rich Text Editor doesn't support the tab feature in this way.
    Please let me know if you have any further questions.
