Searching in new Velocity API results in broken links
  • 1.  Searching in new Velocity API results in broken links
    Posted 11-12-2019 01:09
    as we are evaluating the new velocity engine we are dependent on the new API documentation.
    Unfortunately the search is broken.
    Example:
    It would help us a lot if this could be fixed soon.
    Anna Henke
  • 2.  RE: Searching in new Velocity API results in broken links
    Posted 11-13-2019 14:52
    Hi Anne
    Thank you for submitting a ticket, and for your patience. I wanted to update this thread for anyone watching this discussion. After talking with our IT team, I've found out that the error only happens when someone uses the search function. Finding the same resource via the All Assets works as a workaround. You also mentioned that removing the "/undefined" in the path will lead to the correct documentation. The fixed docs include methods that are only available in 8.44, so IT doesn't want to push the docs out until that release is available. The release date is listed as November 22nd. If anyone has anymore questions, please don't hesitate to reach out.
    Thank you
    Godiva Hunt
