bulk change in test run
  • 1.  bulk change in test run
    Posted 05-31-2018 16:26
    I added a parameter called execution priority in the test run. I would like to be able to quickly change the value of a number of test cases in the test run to the value P1 and the rest of them to P2. Is there a bulk change option or another other way besides going into each test case and change the value?
    Mandy L.
    Mandy L.
  • 2.  RE: bulk change in test run
    Posted 06-01-2018 05:05
    You can do this in list view, by doing a search, or by setting up a filter. Once you have the list of results, you can select multiple items in the list and do a bulk edit of the added field.
    Steve Kay
    Hologic - Breast Health
  • 3.  RE: bulk change in test run
    Posted 06-01-2018 14:36
    Hi Mandy,
    Steve could not have said it any better. The creation of a filter is the best way to accomplish the task at hand.
    Getro Naissance
