When developing a Test Plan, I'm running into a problem at the stage that I'm adding Test Cases to the Plan.
It appears that it is impossible to add a given Test Case to a Test Plan more than once. (I get an error message when I try to do so.)
My guess is that this is probably a feature rather than a bug but, at least from my perspective, it's not a helpful feature.
I'll explain my use case ...
I want to run a sequence of Tests in a particular, prescribed order. So, I drag the relevant Test Cases into a Test Group and put them into the correct order within that Group - so far, so good. BUT, the prescription for the sequence of Tests calls for "Test A" to be performed first (essentially to establish a baseline), then to perform a drop test (call that "Test B"), then perform a vibration test ("Test C"), then to re-run "Test A," then to move on to Test D, etc.
So in a single Test Cycle, the sequence of Test Cases I want to run is A, B, C, A, D
Given that I can't add the same Test Case twice at the "building Test Groups stage, I don't see any way that I can construct the sequence that I want in a single Test Cycle. Is there some way that I can over-ride or work around this (apparent) restriction?
Ian Webb
Enphase Energy, Inc.
