Hi everyone,
we have migrated to Jama 8.10.2 recently and continue to investigate new features and adjust our processes accordingly. One more new behavior we are observing: when clicking on the related item from the "Relationships" side bar of the item the project context switches to the one of the related item. To make it clearer I have "Project A" and a "Test Case A" in this project. This test case is related to the "Test Case B" from the "Project B".
So the Use Case is the following:
- The user works in Project A has several tabs open, including Test Case A;
- Goes to the Related items of the Test Case A and clicks on the Test Case B;
New behavior in Jama 8: project context changes to the Project B. All tabs where the user worked before get closed.
I assume this behavior has been changed intentionally and it is not a bug. If it is the case, is there any background why this has been changed? Was the old behavior when the project context stayed the same in the use case above has been reported as a bug?
Thanks for any inputs on this.
Best Regards,
Ekaterina Kessner
