I have a set which contains a few hundred system requirements. For arguments sake it was set up with a key of ABC, so each item within this set has a Project ID which looks like this:
TESTPRJ-SYSR_ABC-001
I now have a need to potentially change the set key from
ABC to
XYZI can see that the set is editable and I can change the name, however the key seems to be read-only.
Is it possible to firstly change the set key and secondly can the project ID of the child items within the set be updated to reflect the set key, so
TESTPRJ-SYSR_ABC-001 would become
TESTPRJ-SYSR_XYZ-001Thanks.
Andy
