I have a requirement to write the test cases in the jama and the execution of the test-cases will be outside the jama using HW(hardware) test automation tool and fetch that result(Pass/Fail) and update back again in the jama.
So I found the approach of exporting the data from Jama inARQE-XML format (the test-case so that i can modify that with the test results
(Pass/Fail)) but I do not find the option of the importing the modifiedARQE-XMLto the same location(project ID). If the importing option is there, please guide me where I can find that. If not, then please can you illustrate the alternative approach?
Second approach I found is using native REST API to get the info of the test-case, modify it with the results
(Pass/Fail)and update it back via
native REST API. Are the
PUT/POST API are the correct method for the updating info to the ID, as I can see from the description of the method.
[Note:When replying to the email, please CC'd to my colleague
chandra.turha@infineon.com]
pranjay kaparuwan
Infineon
bangalore KS
