Import to update exising items
Jump to Best Answer
  • 1.  Import to update exising items
    Posted 02-22-2017 14:22
    I need to add new fields to existing item types and update those fields from an external source (excel).  Does Jama support this?  I did not see any way to link the Project ID during import and did not want to risk corrupting my data by trail and error.
    Jeff
    Jeff Abbott
    Leidos
    Orlando FL
    407-243-3760
  • 2.  RE: Import to update exising items
    Best Answer
    Posted 02-22-2017 16:42
    Hi Jeff,
    There is a way to do this. Once you add the new fields to your item type, you can export the items to Excel using Roundtrip; this will include the necessary IDs for mapping. Once the values are in the new field in the spreadsheet you can import it back into Jama.
  • 3.  RE: Import to update exising items
    Posted 02-23-2017 05:02
    Thanks Kristina,
    Jeff
    Jeff Abbott
    Leidos
    Orlando FL
    407-243-3760
