We are having the same conversations in our team. Whether to create a new PR when it changes or update the existing one. We, too, are interested in preserving the history.
In our case, we use the duplicate and sync functionality (instead of the release_field) to support the next product release . The main reason we went this way is the constraint that a particular PR can only exist in one release at a time and we need to support concurrent development (we are simultaneously developing multiple versions of our product and many requirements are shared by both projects).
We have also struggled a bit with the need to maintain the same ID as we reference these from outside of JAMA. This becomes a challenge as the ID prefix changes from project to project. We are dealing with this by referencing these items minus the prefix (instead of referencing CR2_REQ_971 we simply refer to it as REQ_971).
At the risk of borrowing this thread conversation, I'd be interested to know if there are better ways we can handle this.
Bob Hunt
Sent: 05-30-2018 10:41
Subject: Product Requirement versioning
@Harald @Getro the need to modify an existed one without recreation is to keep the unique ID of the Requirement, and have a history of the changes made on this PR in our quality system.
So if a change request is made, the ID of the PR where the modifications is requested should be kept the same in the next releases.
after each release, a baseline is created for all PRs. Then for the following releases, modifications are made directly to the items.
Sawsan Abusharkh
Sent: 05-29-2018 18:11
Hi Sawsan,
I agree with Harald. I would not change requirements, I would delete and create new ones for new (changed) abilities.
Getro Naissance
Sent: 05-28-2018 04:45
We currently use the JAMA release management.
The product requirement item has the field "release" of type "Release", to keep track of each release requirements.
so our project will have:
Project
PR1 (release_field = 1.0)
PR2 (release_field = 1.0)
PR3 (release_field = 1.0)
if changes should be made on the existed PR (e.g. PR1) for the next release and other new features (e.g. PR4) are requested.
we simply add the new features and assigning the new release, and modify the existed ones and update the release field.
Project
PR1' (release_field = 2.0)
PR4 (release_field = 2.0)
Is this a good way to use the release management in JAMA?
Sawsan Abusharkh
