Thank you for the suggestion. You can submit a feature request by visiting the community-
here's an article that describes our process.
You can do a quick search for the existing
Feature Request on the Community. If the subject already exists, you can add your use case in the form of a comment. If the request doesn't already exist, use the "Post a Message" link and create a new post in the Feature Request Discussion area.
We will not respond individually to these feature requests with status updates or comments, however, you should expect to see a community post from our Product team after each planning session. We will work to keep you updated on what you should expect to see in Jama and how your feedback shapes the roadmap.
Business Support Engineer
Sent: 08-09-2018 18:29
Subject: Am I limited to 4 columns in the Test Steps?
I also would like to add a column to the test steps.
Is there somewhere we can request this feature ?
David
David Burgess
Boston Scientific - PCIG
Sent: 05-05-2017 13:01
Francesca,
Unfortunately, there is no way that I could find to change / modify the number of columns in the test step table. e.g. no way remove columns or add columns. With that said, no way to change the names of the columns, such as 'Expected Results' to 'Pass Criteria', etc...
Regards,
Ken
Ken G
ASR
Sent: 05-03-2017 19:46
Hi Dana,
If you look at the screenshot, you see that I only have Action, Expected Results and Notes (total of 3 column), and I need to add a couple more columns.
Francesca
Sent: 05-03-2017 19:15
Hi Francesca,
Can you please attach a screenshot of the columns you are referring to?
Dana Medhaug
Jama
Sent: 05-03-2017 18:26
I need one or two extra columns in the Test Steps. Is there a way to add them, or is there a limitation on the number of columns?
Francesca
