To export Office template using Rest API
  • 1.  To export Office template using Rest API
    Posted 05-25-2017 22:36
    Hi Jama Support,
    I want to export Office template using the Rest API. I went through the jama API-docs but didn't find any option.
    Is there any option for exporting office templates using REST?
    Thanking you in advance for your time and consideration.
    Yours sincerely,
    Pranjay
    pranjay kaparuwan
    Infineon
    bangalore KS
  • 2.  RE: To export Office template using Rest API
    Posted 05-26-2017 14:41
    Hello Pranjay,
    From the information I've received through some colleagues the answer is "kind of". There are endpoints to get items and then you can use programming language to output that as a csv file. Basically there is no endpoint that is "export to excel". But there are certainly calls that can help you retrieve all the info that an excel export can.
    Dana Medhaug
    Business Support Engineer
    Jama
