Change in Review Functionality
  • 1.  Change in Review Functionality
    Posted 10-03-2019 12:50
    I remember the functionality in the review center where my rejected items will maintain through the update of the new revision. Was this functionality changed in the new version of the JAMA?
    Rahul
    Rahul Khurana
    Sr. Systems Engineer
    NeuroStar Inc.
    PA
    6109814122
  • 2.  RE: Change in Review Functionality
    Posted 10-04-2019 16:42
    Hey Rahul,
    Thanks for reaching out. While we recently made changes to the review center wizard in 8.42, we haven't made any changes recently to the review center reading view or single item view - the areas where the approved and rejected status icons reside. The review should keep any items an approver has marked approved or rejected (or finished if the participant is a reviewer) when new revisions are published as long as the item has not been edited. Items that have been edited from one revision to the next will result in the respective item's review status being cleared. The idea behind this is to focus the approver or reviewer on the items that have changed from one revision to the next.
    I hope this helps. Please let us know if you have any other questions.
    Joel Hutchinson
  • 3.  RE: Change in Review Functionality
    Posted 10-08-2019 11:47
    Hi Joel,
    Are there any guidelines on reviewing items in JAMA?
    Rahul Khurana
    Senior Systems Engineer
    t 610.981.4122 |
    Customer Service: 877.600.7555
    NeuroStar.com
    NeuroStar is a brand of Neuronetics, Inc.
  • 4.  RE: Change in Review Functionality
    Posted 10-08-2019 11:57
    Rahul:
    I am glad you asked that, I happen to know that there is added documentation that is currently going through an editing process right at this moment from our Product Marketing department. These resources will be made public in the Community soon!
    I will make sure to let the Product team know that your interest is aligned with their communication plan.
  • 5.  RE: Change in Review Functionality
    Posted 10-08-2019 13:01
    Do we have any anticipated dates on which this will be released?
    We are in the wild wild west of reviewing and I am afraid that ppl are going to get frustrated and stop using it.
    Rahul Khurana
    t 610.981.4122 |
    NeuroStar.com
  • 6.  RE: Change in Review Functionality
    Posted 10-08-2019 14:55
    Hi Rahul:
    The anticipated date is at the tail end of this month.
  • 7.  RE: Change in Review Functionality
    Posted 10-09-2019 07:47
    Thank You Chloe.
    Rahul Khurana
    t 610.981.4122 |
    NeuroStar.com
  • 8.  RE: Change in Review Functionality
    Posted 10-31-2019 07:14
    Hi @Rahul:
    Just want to make sure you saw all the resources for the Reviews out, we also updated the User Guide appropriately. There is also a webinar we are signing people up for, which should go more into depth about the new changes. You might have noticed a few posts around the Community about this subject lately, I wanted to make sure I completed the circle of communication.
    Here is a link to the Review Center E-book: Best Practices for Jama Connect Review Center Guide
    Here is a link to the webinar signup: Ask Jama: Tips and Tricks for More Effective Reviews
    Rahul, let me know what you think about these resources and if there is anything else you feel your team needs to get comfortable with the ongoing Review Center updates!
  • 9.  RE: Change in Review Functionality
    Posted 10-16-2019 06:07
    A user noticed that the default condition when adding users to a review is that they are now approvers rather than reviewers. Since we typically have a to more reviewers, this requires a great deal of mouse-clicks to fix. Is there a way to set a default for added users?
    Also, we have intermittent cases of reviews being closed prematurely. Our workaround is to extend the review by one hour to re-open it. Is anyone else seeing this?
    Jamey Potechin
    Crestron Electronics
    Rockleigh NJ
  • 10.  RE: Change in Review Functionality
    Posted 10-16-2019 07:38
    Hey Jamey,
    Great question - I can help clarify the change that led to the user noticing that. When we refreshed the initiate review wizard in 8.42, we decided to make a change to the default settings for review participants. Now, if the moderator has chosen to enable the "Require electronic signatures from approvers" setting in the Settings panel, when they add users in the Participants panel, we default the review role to an approver. When the "Require electronic signatures from approvers" setting is not enabled, when the moderator adds users in the Participants panel, we default the review role to a reviewer.
    The idea here is that we believe more users in reviews requiring electronic signatures will be approvers. We decided to maintain the previous default if the review does not require electronic signatures.
    I would ask the user who noticed the issue if they can check the Settings panel of the review to see if the "Require electronic signatures from approvers" setting is enabled. If that's not the case and the default is behaving incorrectly, let us know and we'll work with you to dig into the issue.
    I'm not seeing the second issue you brought up on our side at the moment.
    I hope this helps. Please let me know if you have any questions.
    Joel Hutchinson
