Hi
@Andrew!
In this case, Keyword refers to the database field of an item type (which is something you have to locate in
Admin > Item Types > [item type] > Config > Field). So some of these fields will be stock Jama fields (name, description), but when it's a stock Jama field, it will likely be in a drop-down for use in embedded fields. The (sparse) documentation that exists for this functionality can be found in the
help guide; it's the last bullet point on the Search Tips page.
Location, however is a different beast-it's not a configured field on items, so it is not possible to use it as a keyword in embedded filters. There is a
feature request for this if you want to add your voice.
Sent: 06-09-2017 10:37
Subject: Keywords in embedded filters
Is there any advanced documentation on using Keywords in embedded filters? I found a blog entry saying using Keywords can be used in embedded filters. I'm specifically looking for the enumerated list of Keywords, formatting of Keywords, and if "Location" is a keyword and if so, how to use it.
Andrew
