Review showing changes to specifications
  • 1.  Review showing changes to specifications
    Posted 01-04-2019 12:31
    We are wanting to do a review that shows changes to a specification since a given baseline.  If we started the review then added the changes afterward, I know we can publish two revisions that way.  What we would like to do is specify a baseline from last year and then have the second be the current revision.  Basically, what has changed since the last time we had a review.  The earlier version is associated with a release as well.  Didn't know if that was helpful or not.  I know we can generate a report with the changes, but I would rather have it as a review, not as an exported document.
    Thanks for the help,
    David
    David Fann
    Center for Medical Interoperability
    Nashville TN
    6152576430
  • 2.  RE: Review showing changes to specifications
    Posted 01-04-2019 16:35
    Hi David:
    Sounds like the report you can generate has all the info you need? Would it work for your organization to then import that same report as an item in Jama? You could then send this to the Review Center.
